VIN 1B3ES56C33D253455. Помогите пожалуйста,на после завтра договорились посмотреть, хочетса знать естьли смысл?может кто смотрел? За рание спасибо. http://cars.auto.ru/cars/used/sale/9089195-60d4.html
прошу пробить vin
Поделиться207.03.2011 01:23
1: Manufactured by DaimlerChrysler Corporation
B: Dodge
3: Passenger Car
E: Restr Sys. Active Drvr&Pass Air Bag(CGW Except-LH)
S: Neon
5: Neon ES (U.S.)
6: 4 dr. Sedan - Body Style (41)
C: 2.0L 4 CYL 16V Gasoline SOHC (SMPI) (ECB)
3: Check digit
3: 2003 Model Year
D: Belvidere Assembly (Belvidere, IL)
Код модели кузова: PLDP41
Двигатель: ECB 2.0L 4 Cyl SOHC 16V SMPI Engine
Коробка передач: DGL 4-Speed Automatic Transmission
Модельный год: 2003
Дата производства: 11.06.2003
*H7: Cloth Low-Back Bucket Seats
-DV: Dark Slate Gray
04MA: FAM:LH TRACKING: 20916L08AB MY:2003
142S: Zone 42-Detroit
1AAS: U.S. Dealer Retail
24J: Customer Preferred Package 24J
2DJA: Customer Preferred Package 2DJ
3VVA: Customer Preferred Discount
594S: Vehicle Order Tracking
5INS: PL-Vehicle Family
623S: Michigan State Code
6USS: Label - U.S. Specifications
923S: Michigan State Code
ADV: Sport Appearance Group
APAS: Monotone Paint
BA7S: 83 Amp Alternator
BCUS: 450 Amp Maintenance Free Battery
BRAS: Power Front Disc/Rear Drum Brakes
CG6S: Center Rear 3-Point Seat Belt
CGCS: Unique Child Tether Restraint
CGWS: Next Generation Front Air Bags**
CKAS: Carpets - Floor and Cargo Area
CKPS: Trunk Dress-Up
CLES: Front & Rear Floor Mats
CLPS: Door Sill Scuff Pads
CSAS: Spare Tire Cover
CUFS: Full Length Floor Console
CUTS: Instrument Panel Storage Bin
DGBS: All 4-Speed Automatic Transmissions
DGL: 4-Speed Automatic Transmission
DHAP: Lock-Up Torque Converter
DLDP: 2.7 Overall Top Gear Ratio
ECB: 2.0L 4 Cyl SOHC 16V SMPI Engine
GADS: Tinted Glass Windows
GBBS: Tinted Windshield Glass
GFAS: Rear Window Defroster
GNES: Passenger Side Sun Visor w/Mirror
GNFS: Driver Side Sun Visor w/Mirror
GNGS: Rear View Mirror w/Reading Lamps
GURS: Power Mirrors
GXRS: Keyless Entry
GXTS: Rear Door Child Protection Locks
GXXS: Sentry Key Theft Deterrent System
HAAS: Air Conditioning
HGDS: Deluxe Insulation Group
JAAS: Instrument Panel
JBLP: Instrument Panel Body Color Bezel
JBUP: Body Color PRNDL Bezel
JCBS: 120 MPH Primary Speedometer
JFHS: Tachometer
JHAS: Var Intermittent Windshield Wipers
JJFS: Single Low Note Horn
JKHS: Glove Box
JKKS: Inside Emergency Trunk Lid Release
JKPS: 12V Auxiliary Power Outlet
JPAS: Power Windows
JPCS: Power Trunklid Release
JPHS: Speed Sensitive Power Locks
K4XS: STRIPE/BADGE/MOLDING/COLOR
LCKS: Front Dome Lamp
LDCS: Trunk Lamp
LMBS: Halogen Headlamps
LMUS: Ft Side Marker/Side Repeater Lamp
LNJP: Fog Lamps
LPNS: CHMSL Lamp
MDAS: Front License Plate Bracket
MFDS: Bright Grille
MGDS: SXT Badge
MGNS: Dodge Badge
ML6S: Front Body Color Fascia
ML7S: Rear Body Color Fascia
MNKS: Body Color Door Handles
MUDS: Dodge I.D. Badge
MV3S: Neon Badge
MXD: Trunklid Spoiler
NAS: 50 State Emissions
NBKS: EVAP Control System
NBVP: Low Emission Vehicle (LEV)
NFMS: 12.5 Gallon Fuel Tank
NHFS: Power Steering Cooler
NHM: Speed Control
PX8: Black Clear Coat
QX8S: Black Clear Coat
RBKS: AM/FM Compact Disc Radio w/Chgr Ctrl
RCGS: 6 Speakers
RDDS: Fixed Long Mast Antenna
SBAS: Power Rack and Pinion Steering
SCAS: Steering Wheel
SDCS: Touring Suspension
SHAP: Front Stabilizer Bar
SUAS: Tilt Steering Column
TBCS: Compact Spare Tire
TQKS: P185/60R15 BSW AS Touring Tires
TZAP: Goodyear Brand Tires
WJBP: 15" Aluminum Wheels
XFAS: -35F Protection Anti-Freeze
YAAS: Build To U S Market Specifications
YEP: Manuf Statement of Origin
YGEA: 5 Additional Gallons of Gas
ZATP: Spring - Left Rear
ZCGP: Spring - Left Front
ZNTP: Spring - Right Rear
ZRFP: Spring - Right Front
Поделиться307.03.2011 01:30
раньше тут было бесплатно
Поделиться407.03.2011 01:36
VIN: 1B3ES56C33D253455 has been identified as a vehicle listed in the VINCheckSM Salvage Records.
Date of loss: 2006-04-18
Cause of loss: Collision
Поделиться507.03.2011 02:25
Спасибо большое, но я плохо разбираюсь в американских терминах, но как я понял выше описанное, это год выпуска и вазможная комплектация. Меня интересует полный карфакс что с ней было в США т.е. на сколько она была утоплена, бита и востановлена после этого. Конечно я понимаю что машина побывавшая у нас в стране и через год может стать ведром, от рук автомехаников которые учатся их ченить на наших не в чем не винных автомобилях. Просто хочется сэканомить время на поездки зарание убитых вариантов. P.S. Если кто собирается продавать живой неончик 2003-2004 до 290000т.р. с чистым карфаксом можете писать в личку, или т. 89265414653.
Отредактировано SanyaFP (07.03.2011 02:48)
Поделиться607.03.2011 09:01
Дословный перевод думаю бедет понятен:
Дата потери: 2006-04-18
Причина потери: Столкновение
Поделиться707.03.2011 11:03
Спасибо дословно понятно! Как думаеш посмотреть есть смысл?
Поделиться807.03.2011 14:35
лучше конечно полный отчет, там скорее всего будет написано куда удар был и как сильно, но это уже платно
Поделиться908.03.2011 11:07
Все всем спасибо, так получилось что эту машину не смотрел, взял другую
, из проблем рейка течет
| Я смотрел эту машину! Это... | Поиск/Покупка Neon | 25.06.2019 |
